Front end vibrations when braking?
Old May 7, 2007 | 04:02 PM
Rikster284's Avatar
Default Front end vibrations when braking?
I have a 2000 G3 Eclispe RS. I recently changed from pads and rotors and caliper bolts (they were pitted). About 2 weeks after the change I begin getting a rather violent vibration when I apply the brakes. My ride is approaching 100K. The vibration is worse when moderately braking at slower speeds. The vehicle stops fine but noticibly shakes to the point to where the steering wheel shakes as well. Has anyone experienced this before and if so is there any direction to correcting this problem. Any help would be appreciated. RT
Old May 7, 2007 | 04:07 PM
Default RE: Front end vibrations when braking?
Warped rotors.
You didnt heat cycle them did you.
Get new rotors and try again [sm=headbang.gif]
Old May 7, 2007 | 04:12 PM
Rikster284's Avatar
Not sure what you mean by heat cycle them? Not your garage guru, just an inexperience weekend warrior. Sorry.
Old May 7, 2007 | 05:10 PM
Dusty Eclipse's Avatar
lol, cmon now Seb, it could be the suspension! Maybe... Wait a minute... Rikster from the Nextel forums??
Old May 7, 2007 | 05:40 PM
Rikster284's Avatar
Nope. never been to a Nextel Forum, sorry. I do not drive this car hard. Would regular driving conditions warp the rotors. I recently put new tires on it and they aligned it. Could it be tie rod ends? I also have never replaced the struts and shocks. Probably hard to diagnose witht he car being that old. If I take it out it does not start the vibration right away. Only after I have been driving for a while. ?
Old May 7, 2007 | 05:41 PM
Nah, Sebs prolly right... sounds like warped rotors
Old May 7, 2007 | 05:43 PM
Rikster284's Avatar
Guess I will give it a shot, can't hurt. Thanks for all of you insight and I will let you know that outcome.
Old May 7, 2007 | 07:44 PM
00GalantMan's Avatar
ORIGINAL: Dusty Eclipse
x2 otherwise it would shake other than when he hit the brakes...
Old May 7, 2007 | 09:50 PM
Yes normal driving conditions will warp rotors.
The heat cycle consists of, driving upto about 100 and reducing your speed to 60 (you dont have to do it really fast) and doing it over and over.
If you buy performance rotors like Brembo. They are a lot less likely to warp
Old May 7, 2007 | 11:34 PM
On the other hand.. if you got em from ebay, you could pretreat em and theyll STILL warp..
