GT 00 Tranny Questions
Old Nov 8, 2007 | 12:38 PM
Camel3g GT's Avatar
Default GT 00 Tranny Questions
What up fellas i cant take the sound of my throw out bearing any longer....what would i have to do to change the throw out bearing. Get a brand new clutch or just a throw out bearing alone.
My car has almost 90k on it now. idk if anythings been replaced.
the tob is so annoying ill be sitting at a light and all i can hear is my throw out bearing until i push down the clutch.
Old Nov 8, 2007 | 02:25 PM
estraw's Avatar
Default RE: GT 00 Tranny Questions
well if your car has 90k on it, you might as well replace everything. tob, clutch, pressure plate, and flywheel. usually when you replace your tob, you should replace your pressure plate anyway. they are usually made for eachother and will often times not work right if you dont replace both. but in your case, i would just replace everything
Old Nov 8, 2007 | 03:49 PM
Wingo171's Avatar
Don't forget to do your Timing belt too.
Old Nov 12, 2007 | 09:16 AM
Camel3g GT's Avatar
anyone know the price of the job needed done? by that i mena replacing the whole system..and anywhere i can find the whole system at a good price
sheer_velocity
May 5, 2011 08:41 PM
venom3230
Jan 12, 2004 08:32 PM
cdipier2
Oct 27, 2003 05:24 AM
ikon_01
Sep 8, 2003 01:03 AM
proformance
May 23, 2003 11:54 PM
