-   3rd Generation (https://mitsubishiforum.com/forum/3rd-generation-64/)
-   -   Headlight Halo Ring Help!! (https://mitsubishiforum.com/forum/3rd-generation-64/headlight-halo-ring-help-33556/)
gerry1502 Aug 22, 2009 11:53 AM
I bought some new headlights for my 01 Eclipse and I wanted to connect the Halo Ring cables to the parking lights, not the signal light...the problem is that the last time I tried checking to see which cables were the ones that don't make it blink the signal light fuse fried :confused:. So if anyone who has done this before please tell me which two cables are the right ones!! I would really appreciate it...:)
jason clipse Aug 23, 2009 05:03 PM
u probably hooked it up backwards
gerry1502 Aug 24, 2009 12:49 PM
No, I didn't get to hook them up at all...I tested the cables with a circuit tester and that's how the fuse blew up...I just wanted to know which two out of the three cables are the ones that don't flash...
jason clipse Aug 24, 2009 07:03 PM
well one of those cables is a ground and the other two are power. what color are the wires?
JKillz11 Aug 25, 2009 10:56 PM
i have the same headlights i just hooked them up to my parking lights by splicing the wire and matching the color of the wire. my parking lights also dont work but the ring still does.
gerry1502 Aug 25, 2009 11:02 PM
I'm gonna check out the colors of the wires tomorrow and I'll let you know...thanx for the help...
jason clipse Aug 26, 2009 11:03 AM
u should use a piggy back splicer, that way u will get power from the wires without actually cutting them. it will probably allow you to keep both your parking lights and the halo ring
gerry1502 Aug 26, 2009 11:11 PM
Well, one of the cables is green, one is red and black and one is black...I'm guessing that the black one must be ground but I don't know which of the other two is the right one...
