Mileage
Old Nov 6, 2005 | 05:06 PM
mitfan's Avatar
Default Mileage
All,
I am new to this group and to cars. I've recently bought a used Sypder GT 2001 model.
I have been experiencing problems regarding mileage and thought would get some information here. I get a max mileage 15-16 miles per gallon. Wanted to have some information regarding this. I've searched a lot on the web and found that it should be giving around 20 mpg on city roads.
Are there any check points to increase the mileage? I've recently got my oil changed but does not improve thigs. :-(
Can anyone suggest me something on this?
Old Nov 6, 2005 | 06:28 PM
Default RE: Mileage
you need a tune up... how many miles are on it?
Old Nov 6, 2005 | 07:40 PM
Sanguinius's Avatar
Default RE: Mileage
Replace spark plugs, wires, distributor cap and rotor (If applicable), fuel filter, decarbon the fuel system and intake. that should give a good start on the problem you should be getting more than 20 MPG city...
Old Nov 6, 2005 | 07:46 PM
Patrick's Avatar
Administrator
Default RE: Mileage
my car with the same engine gets 24/28
Old Nov 6, 2005 | 08:13 PM
Lil red's Avatar
Default RE: Mileage
Your in a bad need for a tune up. its all things you can do with a few common tools and an hour or two. nothing hard....
Old Nov 7, 2005 | 10:10 AM
Sanguinius's Avatar
Default RE: Mileage
Yep get a spark plug socket and rachet new spark plugs, wires, oh and don't forget to change the air filter while you're at it.
Old Nov 7, 2005 | 11:33 AM
eclipsed4u's Avatar
Default RE: Mileage
ORIGINAL: Lil red
two hours? i hope you don't plan on changing the spark plugs in that tune up.
Old Nov 7, 2005 | 05:12 PM
Sanguinius's Avatar
Default RE: Mileage
What?? If he can't change spark plugs in less than an hour then he needs SERIOUS help... But he NEEDS more than just the plugs/wires changed. And what needs done will DEFINATELY take more than an hour.
Old Nov 7, 2005 | 05:24 PM
eclipsed4u's Avatar
Default RE: Mileage
ORIGINAL: Sanguinius
ok....from this statement, i can tell that you don't have a 3G v6. to replace the spark plugs on the 3G v6, you have to remove the intake manifold. even the most knowledgable mechanics take more than an hour.
here is the how-to on how to do it. http://66.29.101.66/~c3g/forum/showthread.php?t=455
Old Nov 7, 2005 | 05:35 PM
Sanguinius's Avatar
Default RE: Mileage
Ooo that's a good point... Sorry I'm only thinking of the 4's I forgot they actually had the 6's in some... My bad....
