NEED HELP!!!
Old Aug 24, 2008 | 01:46 PM
robd690's Avatar
Default NEED HELP!!!
I Have a 2000 eclipse GT. Battery light and brake light flicking on and off. I thought it could be a bad alternator so I replaced it. Problem did not go away.Lght stays on now and drains the battery. I beleave it is a groung short. Could someone that may have had this problem maybe tell me were it is coming from. I will have to chase wires otherwise which will be a pain in the ***. Can someone help me??????
Old Aug 24, 2008 | 03:47 PM
mack29730's Avatar
Default RE: NEED HELP!!!
check the ground wires on the battery and the one going to the body. also have your battery check could have bad battery.
Old Aug 25, 2008 | 07:58 AM
andry's Avatar
is your battery good? is there another problem like hard starting? if yes it could be battery problem.
Old Aug 25, 2008 | 08:48 AM
i would start by checking the terminals on the battery. Alot of times they will get corroded and cause a bad connection and alot of times not allowing them to be charged by the alternator.
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
