need some help
hello new here to the forum , im working on a friends 02 eclipse 3.0 . car ran out of coolant and died on the road (dont know more then that), so i cranked the car with fresh water (for testing) and it spit out of the radiator as fast as i poured it in , blow head gasket. so i pull the heads and notice big holes carved into the head where there not meant to be ( my thoughts hot stem eating aluminum). replaced heads and all gaskets , now i have 30 psi of compression on cylinders 1-5 and 90 on 6 , does any one think the cam could be out of timing or maybe something more serous. any help would be much appreciated. thank you
i think you mean "au contraire" and i dont think you quite grasp its meaning, nor usage.
figured it out, pulled a rookie move , when they shiped the heads all the valve adjustment was pulled out except the one with compression( cause that one was probably on a compression stroke when pulled of the other car), so there lies the problem no valves opening no compression . thanks for no help akzle, i would never let an ******* like you even speak towards me, and for the others thank you for your thoughts
