need some help
Old Apr 24, 2014 | 08:06 PM
Robert Smith's Avatar
Default need some help
hello new here to the forum , im working on a friends 02 eclipse 3.0 . car ran out of coolant and died on the road (dont know more then that), so i cranked the car with fresh water (for testing) and it spit out of the radiator as fast as i poured it in , blow head gasket. so i pull the heads and notice big holes carved into the head where there not meant to be ( my thoughts hot stem eating aluminum). replaced heads and all gaskets , now i have 30 psi of compression on cylinders 1-5 and 90 on 6 , does any one think the cam could be out of timing or maybe something more serous. any help would be much appreciated. thank you
Old Apr 24, 2014 | 10:39 PM
Akzle's Avatar
i would never lend you or your friend any of my vehicles.
Old Apr 24, 2014 | 11:48 PM
i was not driving the car my friend was
Old Apr 25, 2014 | 12:09 AM
mxmikie's Avatar
dont mind Akzle he is a contraire everything he says is the opposite of what he means ..... if you cant dazzle em with brilliance..... baffle em with bull sxxt
Old Apr 25, 2014 | 07:11 AM
jkeaton's Avatar
If it overheated to the point of "dying on the road", I would think a lot more serious damage was done. It is running now? Are you sure you got it all back together correctly?
Old Apr 25, 2014 | 01:38 PM
Akzle's Avatar
i think you mean "au contraire" and i dont think you quite grasp its meaning, nor usage.
Old Apr 25, 2014 | 06:48 PM
figured it out, pulled a rookie move , when they shiped the heads all the valve adjustment was pulled out except the one with compression( cause that one was probably on a compression stroke when pulled of the other car), so there lies the problem no valves opening no compression . thanks for no help akzle, i would never let an ******* like you even speak towards me, and for the others thank you for your thoughts
Old Apr 25, 2014 | 11:14 PM
Akzle's Avatar
that time of the month, huh.
Old Apr 25, 2014 | 11:27 PM
mxmikie's Avatar
well take some aspirin Akzle you will be ok
Old Apr 26, 2014 | 04:13 PM
jkeaton's Avatar
Glad you got it figured out.
