Oil leak.. crap!
Oil leak.. crap!
hey, i thought i fixed my problem but no. i found another spot of oil on my garage floor under my car. i found where its dripping from but cant find where the actual leak is. it looks like its coming from behind the clutch dust cover (or whatever that piece is called) but idk how it got there to begin with. any ides? here are some pics
you can see where its leaking around the bolts[:@]
RE: Oil leak.. crap!
ORIGINAL: magnet
yes..its the rear main seal. Remember to buy the steel crank repair sleeve and tap it on the crank before you put in the new rear main seal.
it means if the rear main seal is bad, the crank probably has a slight groove in it and to buy the crank repair sleeve. have you not ever heard of this?
heres a link that shows what I mean IF your problem is the rear main
http://www.microsleeve.com/csrs.html
man, i dont wanna tear my whole engine apart, i was just hopin i had to replace the oil pan gasket and rtv, ill start with that and if that dont fix it, i guess ill have to go with your suggestion. thanks
TheRock0720
11-12-2010 12:30 PM
doubleballer2123
02-24-2005 03:04 PM
