power steering fluid?
Old Dec 13, 2005 | 09:07 PM
Hawks's Avatar
Default power steering fluid?
Hey everyone. I've got a 2002 eclipse gt. My power steering fluid is a little low. My owner's manual says to use "Diamond ATF". I called two dealers and one said to use regular power steering fluid and the other dealer said to use dexron transmission fluid. Which is it? Also, what brand do you recommend.
Thanks!
Old Dec 13, 2005 | 10:03 PM
slow420a's Avatar
Default RE: power steering fluid?
castrol dot4 can be baught at walmart for a cheap *** price, its synthetic, cheap, and works.
Old Dec 14, 2005 | 01:15 AM
Joel_CA's Avatar
Dextron II will work fine. Do NOT use Mitsu SPIII ATF as this will cause havoc on your power steering system. There's a techtalk article warning us not to use it for PS fluid. IF you can get your hands on Diamond SPII fluid, you'll be fine. Before SPIII ATF came out- SPII was always used as the PS fluid.
Joel, CA
Old Dec 15, 2005 | 11:08 PM
wsuweston's Avatar
Dexron II ATF
Old Aug 25, 2010 | 10:05 PM
Hadean's Avatar
I got for my Eclipse 2003 a Justice Brothers Power Steering Service /Flush/Fluid/Treatment from a local Mitsu dealer. $27 for 2qt bottle.
tj90
Apr 16, 2023 09:53 PM
ccernst
May 24, 2016 03:50 PM
cheech
Nov 15, 2011 03:39 PM
4g63419
Feb 11, 2008 11:28 AM
jcasaccio
Jun 6, 2006 06:14 PM
