Power window problems
2003 GTS Spyder.
Put the top down last night got it home put the top up and tried to put the windows up, only the driver side would go up. Checked all fuses OK. Swapped the relay in the cabin fuse box bottom to middle, middle to bottom same part # MR515993 and all seems good. The relays were clicking as I think they should when the top switch is activated. Looking through the fourms I have see a couple of threads covering the master switch. Just tring to determine if it is truly a relay problem or possibly the switch? I don't have a wiring diagram and don't know what the other relay goes to, everything seem to be working. Any help? Thanks
3000gt1999
Jan 11, 2007 09:12 PM
tunit7
Jul 19, 2005 08:09 PM
