problems starting 2004 eclipse
Old Jun 21, 2007 | 10:34 PM
jwillia2000's Avatar
Default problems starting 2004 eclipse
[X(]my daughter let her car run out of gas. We put some in but still won't start. Any help or ideas?
Old Jun 21, 2007 | 11:14 PM
I Drive Naked's Avatar
Default RE: problems starting 2004 eclipse
fuel pump most likely.
they don't like to be run dry.
You should always fill up around 1/4 tank
Old Jun 22, 2007 | 05:51 AM
How much gas did you add? How long did you try starting it? It might take alittle bit to get it to start back up again. But im with josh on the fuel pump.
Old Jun 22, 2007 | 08:21 AM
bigwayner's Avatar
Yup most likely the pump.. never good to let them run out.
Old Jun 22, 2007 | 11:48 AM
I replied to the other thread
Old Jun 22, 2007 | 12:06 PM
NubianSithLord's Avatar
Is the car on a level surface? I know it sounds simple but that happened to me before and it was the incline towards the curb.
Old Jun 24, 2007 | 06:38 PM
yea, the shop said fuel pump. $300 lesson learned. She also has the display for her music station out. Fuse maybe? Thanks for all the help!
Old Jun 24, 2007 | 06:55 PM
Possibly fuse, maybe wire harness. Electrical problems other than simple fuses are almost impossible to solve on here.
Old Jun 25, 2007 | 02:43 AM
bigwayner's Avatar
In another thread a guy said his display went out because his cigarette liter fuse was shot. Don't know if it would be the same case here.
Old Jun 25, 2007 | 07:28 PM
turned out not to be fuel pump. fuse was not plugged in
Jmwatson14
Jan 13, 2016 06:14 PM
jp2000
Jan 1, 2012 05:21 PM
jwillia2000
Jun 24, 2007 04:16 PM
cagiestbat
Nov 14, 2005 05:13 PM
Parker
Sep 23, 2003 01:27 PM
