Rear differential fluid?
Hey guys, do you know which fluid is needed to drain and refill the rear differetial on my Eclipse GS 2.4L?
My toyota camry uses Mercon/Dex III for transmission and differentials. Do I need to use the expensive Diamond SPII on my Eclipsedifferentials too? [:@] |
RE: Rear differential fluid?
Your car is FWD, it doesn't have a rear diff.
If you're asking about tranny fluid for automatics. I would highly suggest the stock stuff of which you've already stated. ;) |
Yeah, sorry... I meant transmission. Ok, I bought some Castrol Import ATF which states that it meets Diamond II specs. It's $3.99/qt. at autozone.
Thanks :eek: |
