Rear differential fluid?
Old Aug 30, 2007 | 02:05 AM
Gerry55's Avatar
Default Rear differential fluid?
Hey guys, do you know which fluid is needed to drain and refill the rear differetial on my Eclipse GS 2.4L?
My toyota camry uses Mercon/Dex III for transmission and differentials.
Do I need to use the expensive Diamond SPII on my Eclipsedifferentials too?
Old Aug 30, 2007 | 03:09 AM
silvercoupe97's Avatar
Default RE: Rear differential fluid?
Your car is FWD, it doesn't have a rear diff.
If you're asking about tranny fluid for automatics. I would highly suggest the stock stuff of which you've already stated.
Old Aug 30, 2007 | 03:44 PM
Gerry55's Avatar
Yeah, sorry... I meant transmission. Ok, I bought some Castrol Import ATF which states that it meets Diamond II specs. It's $3.99/qt. at autozone.
Thanks
monterodiff
Jul 4, 2013 05:11 PM
monterodiff
May 23, 2011 10:27 AM
4never
Sep 23, 2010 12:10 PM
melandmart4
Feb 5, 2009 06:58 PM
pdc001
May 21, 2007 08:43 PM
