somethings leaking... i need help?!!
Old Jun 5, 2006 | 07:30 PM
anfchick025's Avatar
Default somethings leaking... i need help?!!
i drive a 2000 eclipse RS..... and something is leaking in my car on the drivers side floor matts and carpet... i cant figure out where is is coming from. there is a very funky odor and everything was soaked... it has smelled for about 2 weeks now, but i never noticed it being wet because i rarely go in my back seat. does anyone know what this might be and how i can fix it? i took out the matts and left my windows and doors open to dry everything out, but i dont think that was the main problem...
please help!!!!!! [>:]
Old Jun 5, 2006 | 07:53 PM
93eclipsegsx's Avatar
Default RE: somethings leaking... i need help?!!
maybe weather stripping from around the door.
Old Jun 5, 2006 | 08:34 PM
2nd g eclipse gst's Avatar
i had a similar problem with my eclipse but it was on the passenger side and the cause was the air con was leaking
Old Jun 5, 2006 | 09:38 PM
how did u get that fixed, did u have to take it in... or could i do it myself? lol sorry i dont know too much about cars
Old Jun 5, 2006 | 09:44 PM
yea i had a mechanic fix it just to be safe
Old Jun 5, 2006 | 10:56 PM
Sanguinius's Avatar
Look you need to check the liquid. Try and soak some into a white rag. Check your coolant level. If the white rag turns greenish then it's your heater core leaking antifreeze into the car. If not then what you'll need to do is likely climb under the car and find the drip hose for the AC. Get a wire coathanger straighten it out and slide it into that tube to clear it out. If it's the heater core then to the shop she'll go. Those are a pain to do as you'll have to take the entire dash apart to remove and replace it.
Old Jun 5, 2006 | 11:47 PM
ncyankeealva's Avatar
Yeah... I would try that. My moms car had the same prob, one of the drain lines were clogged. Caused a mess when it rained.
Old Jun 6, 2006 | 12:48 AM
sorry, i thought you said rain was coming from the top
Silver00GT
Apr 30, 2009 05:44 PM
imapirate30
Jan 7, 2007 02:37 AM
FutureEVOwner
Jun 3, 2006 01:00 AM
FatalJRA
Oct 30, 2004 05:32 AM
