Spyder Trans Problem
2001 Eclipse Spyder.....Trans slipped into neutral while driving (neutral indicator light was flashing) pulled over shifted to park, putback into drive but vehicle was in reverse!Now it won't shift at all, when car is off with the key onI can hear the shift motor when I use the "tronic" shifter.But, could it be bad? Could I have a bad TCM? Can anyone help me???
RE: Spyder Trans Problem
I personally was'nt driving but I know there is no check trans light.......I was told neutral light was flashing but it easily could've been theOD light flashing, believe it was trying to shift from 3rd to 4th gear into overdrive, that would make sense. But it won't shift at all now.
Usually the shift solenoids are part of the valve body or main control assembly. Replace that and you should be ok,as long as u dont have like an incorrected #2 gear ratio or something. How many miles are on the trans?
I believe 97000 miles on car.I thinkI should get a code telling me if the ratio's are off, ormaybe not.I am going to replace the whole valve body assembly. Can I access the VB without dropping the trans?
i almost have the same problem but i hav a 98 eclipse spyder with a 2.4 L engine non turbo like when i drive up 2 45mph the car will go into nertual and the car will rev until i drop speed 2 20mph and its goes back into gear.. idk what is the problem
99_Spyder_GS_Zombie
10-18-2010 10:13 PM
