Water in back seat!!!
Old May 2, 2016 | 08:21 PM
1bignordic's Avatar
Default Water in back seat!!!
Greetings! I'm new to your forum and hope I'm in the right section. I have a 2003 Eclipse and am having a frustrating problem. Whenever it rains the back seat bottom cushion gets wet, along with the retracted part of the seat belt, the seat belt that is for the front passenger but is located in the back seat. And also the floor, again passenger side rear gets sopping wet! I'm not sure where the water is coming in and was wondering if anyone here has had the same problem??? Any input would be greatly appreciated!
Sincerely,
1bignordic
Old Jun 27, 2016 | 11:46 AM
dsty's Avatar
the drains are located just in front of the rear tires, you will see a 6in. narrow opening, that is the drains for all the water that falls on the roof. make sure they are clear.
I had the same problem but for a different reason. the bladder in the top well came loose and was sending water all over. this liner has a connection that holds both sides together and one side came off. the material was torn so I folded some material to make a three layer repair, glued with 3 m spray and then added a grommet from the craft store. Parking on an extreme hill or sideways may cause some leaks I hope this helps someone. note; the top well should only get water from putting down the top when wet.
Mitsugurl
Jul 22, 2018 08:51 PM
JohnnyK
Jun 2, 2011 01:10 PM
theoh
Nov 9, 2009 05:43 PM
wackles7
Apr 19, 2005 08:32 PM
jdmeclipse92
Oct 29, 2004 12:58 AM
