What to do with it?
Old Apr 16, 2008 | 04:46 PM
teetdogs's Avatar
Default What to do with it?
Ok so I am getting my head unit replaced on sat. and am wondering if anyone has any good ideas as to what to do with the old display that is mounted in the dash, has anyone come up with alternate uses for it once the factory deck has been replaced? Can the clock be made to still work?
Old Apr 16, 2008 | 08:10 PM
Default RE: What to do with it?
I always thought the clock will work still but not sure. I have seen people mount SAFC2s behind there or some forms of a wideband guage display for the turbo guys
Old Apr 18, 2008 | 11:21 AM
Silver00GT's Avatar
when i bought my eclipse it already had a sony head unit installed and the clock function stills works on the display on the dash...wasnt aware until i joined this forum that it originally had a temp. function as well, but i guess that is disabled once an aftermarket deck is installed, but as i said the clock still works on mine.
Old Apr 25, 2008 | 09:54 AM
firebuck's Avatar
the clock and temperature should still work. The display also shows what radio stationyou are on. That will probably not work.
I have seen everything from 2 or 3 gauges to safc2 as well as tv monitors and gps systems. You could put almost anything there.
