-   4th Generation (https://mitsubishiforum.com/forum/4th-generation-65/)
-   -   Brake pedal sound is worrying me (https://mitsubishiforum.com/forum/4th-generation-65/brake-pedal-sound-worrying-me-8352/)
cllamont Feb 16, 2006 04:03 PM
RE: Brake pedal sound is worrying me
Its in the car. I cant press the pedal and listen under the hood because my legs arent that long. I have no friends to do it for me either.
autodoc68 Oct 6, 2014 02:21 PM
Does anyone have a problem with soft pedal feel and you've replaced the master cylinder and it's still the same?? I also flushed the system 3 times. I've found that when you cycle the ignition, the pedal changes after that. It is related to the ABS system as I have done a few panic stops and the brake pedal comes back sometimes. I also get a "hoot" noise when I lift the brake pedal. The Master cylinder has been replaced, but still the same. I need a permanent fix for this. I am a licensed mechanic, but frustrated with this car as it's my Girlfriend's car.
