4th Generation This includes all Eclipses built in 2006 and 2007.
Check Engine Light form Intake ?wtf?
Old Apr 8, 2008 | 11:31 PM
backagain08@aol.com's Avatar
Default Check Engine Light form Intake ?wtf?
I put a cold air intake on my Eclipse gs and the check engine light came on? Has anyone else experienced this if so what can you do about it?
Old Apr 14, 2008 | 03:23 PM
4GD's Avatar
4GD
Default RE: Check Engine Light form Intake ?wtf?
Have you checked to make sure you hooked everything up correctly? Did you plug the sensor back into the intake pipe?
Old Apr 14, 2008 | 04:30 PM
dsm1990gsx's Avatar
Yep like what 4gd said make sure everything is hooked up right and plugged in and no vacuum lines left disconnected.
Did you get the car scanned?
Old Jun 10, 2008 | 03:50 PM
WS6KLR's Avatar
It is more than likely a misfire code. That code is actually pretty comon when you alter airflow without a fuel computer to tune it.
Old Jun 10, 2008 | 03:51 PM
Reset the ECU by removing the battery for 20 seconds with the keys in the ignition.
Old Jun 10, 2008 | 05:06 PM
silvercoupe97's Avatar
If you removed the stock air box and replaced it with a cone filter...there's your issue. Your intake is now sucking up all the heat that your motor makes and is causing the CEL. It's nothing you did wrong.
It's best to get a K&N replacement filter and hacking the original tubing that goes into the fender to open it up.
Old Jun 10, 2008 | 05:10 PM
I hate this little bug the board is experiencing. It's pissing me off.
Old Jun 10, 2008 | 05:55 PM
dsm1990gsx's Avatar
ORIGINAL: silvercoupe97
Tell me abt it everytime I make a long post I get "cannot find page display", Its driving me nuts!
Clipse1
Apr 25, 2014 11:51 AM
jeedizzle
Oct 13, 2009 10:13 AM
95talonesi
Apr 25, 2008 11:52 PM
thewilltolive
Apr 28, 2004 12:12 PM
