4th Generation This includes all Eclipses built in 2006 and 2007.
Problem shifting 06 Eclipse
Old Oct 15, 2006 | 10:24 PM
leedesert's Avatar
Default Problem shifting 06 Eclipse
I'm having trouble with the 6 spd shifter on my 06 Eclipse GT. When accelerating harder than normal driving I keep hanging up from 2nd to 3rd. It feels like the shifter is hitting a wall so I have to move it around to find the 3rd gear slot. In my opinion the shifter requires a bit more effort than what I would consider normal.
The car only has 11,000 miles and hasn't been raced so I don't think the clutch is worn.
Is this charectoristic of the car or is this something I should let the warranty take care of?
Old Oct 15, 2006 | 10:25 PM
Default RE: Problem shifting 06 Eclipse
definetly warrenty. It sounds to me like you have a bad syncro in the tranny since its only in that one gear. Id definetly bring it back to the dealer
Old Oct 15, 2006 | 10:30 PM
Damn you. Always taking the good ones....
Either that or its an alignment problem... or you have a little air in the clutch lines....
Although im willing to bet its a syncro.
Do we grind our gears a little leedesert?
Old Oct 15, 2006 | 10:38 PM
leedesert's Avatar
No, never grinding just get hung up going into 3rd like the shifter is catching on something. It doesn't do it all the time. Probably depends on what RPM I'm shifting at. If I take 2nd out above 4k and try to move into 3rd quick it catches.
Old Oct 15, 2006 | 10:41 PM
hmmm... why not try a high rev downshift... then tell me if it grinds between the gears.
My bro had a bad syncro on his 2003 Infinity G35... turns out it was a recall. The tranny was fine going up the gears... but when you downshifted.. if you didnt match the revs perfectly you got a fat *** grind and everyone looks at you laughing.
Old Oct 15, 2006 | 10:44 PM
leedesert's Avatar
I'll play around with it a bit more and see. I might be trying to cut the transition from 2nd to 3rd to tight, hitting that spot between 1st and 2nd.
Old Oct 15, 2006 | 10:46 PM
no that shouldnt happen anyway. It should be smooth and spring assisted. Maybe you have lost one of the sptrings or bent one of the guids.
TA350
Mar 28, 2015 06:28 AM
Tony3448
Other Mitsubishi Models
Jun 4, 2012 01:16 AM
and2y105
Jan 31, 2007 12:33 AM
hoosierdaddy_87
Jul 5, 2006 09:28 PM
chrisohki
Jul 29, 2004 11:45 PM
