4th Generation This includes all Eclipses built in 2006 and 2007.
Are Toyo Winter Tires Good?
Old Nov 11, 2005 | 12:19 AM
Warren's Avatar
Default Are Toyo Winter Tires Good?
After weeks of research I have finally found out that my 2006 Eclipse GT will take a 16" steel rim fitted with P205/65 R16 winter tires.
With my previous vehicles I have used all the most common manufacturers such as Goodyear, Bridgestone, Michelin and BF Goodrich. All these tires have been tested and rated by Consumer Reports. Most of these tires typically have a Q speed rating.
I am thinking of going with Toyo snow tires which have an H rating. I actually can get these cheaper than the more common Q rated tires. The problem is I have never used Toyo before and Consumer Reports did not rate them.
Has anyone used Toyo winter tires? Are they a good quality tire that will last? Are they as good as Blizzak's, X-Ice, etc?
Old Nov 11, 2005 | 02:07 PM
Patrick's Avatar
Administrator
Default RE: Are Toyo Winter Tires Good?
how is the price? if they are anywhere near as much as the blizzaks, get the blizzaks..
Old Nov 12, 2005 | 01:10 AM
Warren's Avatar
The dealer quoted me $890 which includes 4 16 inch steel rims, 4 H rated Toyo tires P205/65 R16 installed, balanced and including taxes. The rims are about $90 each so the tires are approximately $116 each. The cheapest Bizzak's I could find were $148 each.
Bizzak's were my first choice. I changed my mind only because the Toyo's are cheaper, they are H rated instead of Q rated and the Mitsubishi dealer has them available. If I thought the Bizzak's were a much better tire even though they are Q rated, I would spend the extra money.
Old Nov 12, 2005 | 12:12 PM
Patrick's Avatar
Administrator
i am not famliar with the toyo snow tire, but i am familiar with the blizzaks...and they are very good...
Warren
4th Generation
Oct 8, 2012 01:04 PM
newoutlanderfan
Mar 31, 2012 07:34 PM
rdenis
Nov 8, 2011 01:10 PM
Fre$h_turk
Apr 4, 2007 02:14 PM
Warren
Oct 22, 2005 06:40 PM
