Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2010 outlander/pac SWI-PS
Old Jun 19, 2012 | 02:11 AM
Rezdawgaudio72's Avatar
Default 2010 outlander/pac SWI-PS
Hey guys need some help with last piece of my car audio install puzzle,wiring & programing PAC SWI-PS,I've been thru PAC's web,thru the install instructions,traced the wires,comes back to same that they say to wire to,second on left on top/second on bottom, numbers very from wire or pin side,so needs to be programed to version #8(with note 9)which is steering wheel control buttons have a wire for each(but only found blue/grey dot wire) to be same,has anyone wired one of these PAC SWI-PS module into a 2010 outlander with success and what wire or wires did you use,I've been doing car audio for 20yrs so i know what I'm doing,just havent programed or installed on of these,so pac says to use pin 22/32 as stated above,but they say 32 is the black ground,on this harness its pink,but does connect to a ground block of main wire harness, thanks
(btw,rest of install is pioneer MVH-P8200BT hu,2sets Almani S7 6.5" comp sets,massive audio NX4,MTX12" in bassworx box mtx 3001 classd amp,knuconceptz 4ga wire/fuses,monster wire rca's,Setup hits hard & so clear,if you guys havent heard of or tried Almani speakers there freakn amazing)
armymen
Feb 5, 2011 10:10 AM
Hansp1
Aug 25, 2010 06:02 PM
MAK312
Aug 25, 2010 01:26 PM
greengrounds
Jan 20, 2010 06:59 PM
roach
Oct 31, 2008 04:39 PM
