Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Blinker Light MOD
Old Oct 25, 2008 | 09:52 PM
eclipse_man420's Avatar
Default Blinker Light MOD
I have 96 eclipse and just changed over the gauges to a reverse indeglo set up. The kit I bought came with 2 led lights to change over the turn signal light from green to blue. I have located where the LED's that go into the back of the gauge cluster that are a twist and pull type of plug with the LED at the end of the plug. Does anyone know how I can replace the LED's? I tried pulling on them but don't want to apply to much force to break the LED.
Old Oct 25, 2008 | 11:12 PM
silvercoupe97's Avatar
Default RE: Blinker Light MOD
I don't understand the question.
Does the LEDs that were supplied have the plug included or are you supposed to remove the bulbs from the base and put the LEDs in its place?
What is it that you're trying to pull off again and from what?
Old Oct 26, 2008 | 02:07 PM
hi sorry I'm not sure if I should have posted this in this section of the fourm..i'm a noob
What I'm trying to do is turn the color of the turn signal lights in the dash a different color.They flash green when you flip the switch to indicate your turning either left or right or have your hazards on; or if you live in RI like me ppl out here don't like to use turn signals. What I wanted to do is change the light from green to blue....here is a pic of the final look
[IMG]local://upfiles/18661/CD1CD27E68EA4C72BB672600430B5B9E.jpg[/IMG]
DougD
Jul 15, 2015 10:53 PM
Scubba.steve
Jan 26, 2008 11:32 PM
athlete1012
Nov 24, 2007 07:37 AM
97gsdragon
Jun 2, 2007 06:46 PM
Alvin
May 27, 2006 03:12 AM
