Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Installing an aftermarket sterio
Old 04-20-2004 | 09:38 AM
madmat's Avatar
Default Installing an aftermarket sterio
congratulations on a clean install sorry<IMG src=smileys/smiley20.gif border="0"> you lost the dough tho<IMG src=smileys/smiley21.gif border="0">
Old 04-22-2004 | 02:38 AM
1rippinGT's Avatar
damn how can you mess it up that bad, stereo installs are the easiest thing. i used to have a 94 civic hatch and the wiring was so messed at first that when i turned the stereo on the lights would turn on. can you say GHETTO. its real easy to do. here is a helpful hint: play the color wired matching game:<IMG src=smileys/smiley3.gif border="0"> it works very well
Old 04-22-2004 | 09:39 AM
madmat's Avatar
I have been doing my own stereo work &amp; and for other peoplefor 10 yrs and only cut into fac wires once..... on a 74 ford pickup.
Old 04-22-2004 | 11:35 AM
Tmann26's Avatar
I can install stereo's no problem, but I never had to mess with a factory amp before... and since there are 7 total speakers in the car, I wasn't about to start hacking and slashing the wires, lol.
Old 04-24-2004 | 03:00 AM
Seth's Avatar
I'm getting sick of messing with wires doing the turbo engine conversion on my pulsar was enough had to rewire the loom so the ecu would sit under that passengers side seat and i had to than rewire the battery in the boot cause there is no room to fit it back in the engine bay <IMG src=smileys/smiley17.gif border="0">not to mention rewiring everything else back up amp, dash, sensors. It can be a nightmare. <IMG src=smileys/smiley11.gif border="0"></P>
Seth <IMG src=smileys/smiley15.gif border="0"></P><edited><editID>-=Seth=-</editID><editDate>38101.0429861111</editDate></edited>
Old 04-24-2004 | 05:28 PM
1rippinGT's Avatar
well even if the car has 7 speakers and an amp it should still be easy. just run the remote wire to the factory amp and then figure out what wires go to the front speakers and the wires that go to the rear speakers.
Old 06-04-2004 | 02:41 AM
zorchrog's Avatar
Default RE: Installing an aftermarket sterio
Its not that easy, if it is anything like my 2002 eclipse with the infinity crap. There is a serial type wire running from the head unit to the factory amp. I just cut and rewired. Bad part is that i lost my instrument lights during the install. Its not a fuse, Any Clues?
Old 06-14-2004 | 04:59 PM
pandiebeer's Avatar
I just got my 2002 Eclipse and it has the 4 disc changer Infinity set-up with a cassette player. I am hoping to take it out and install my Pioneer headunit with the rear aux output for direct plug in for my iPod. Going by the post above it seems that you can actually use the factory amp? Is this recommended or should I just leave the amp and bypass the wiring to an aftermarket one for an easier install? My boyfriend left his factory amp in his '93 Mustang and wired around it. He's good at 'typical' installations and has a good general knowledge of how stuff works. Would it be worth getting someone to just do it for us or does it seem easy enough on our own? Judging by everyone's posts it sounds pretty easy with the right harness and wiring kit.
wmjan2107
03-31-2010 09:36 AM
Catch22!
03-20-2008 11:42 PM
stephengrossman
01-22-2008 08:19 PM
sturpon711
09-17-2007 05:23 PM
Tmann26
06-14-2004 04:59 PM
Quick Reply: Installing an aftermarket sterio
