-   Audio/Visual Electronics (https://mitsubishiforum.com/forum/audio-visual-electronics-21/)
-   -   LED ACCENTS (https://mitsubishiforum.com/forum/audio-visual-electronics-21/led-accents-28177/)
PoolhallJunkie777 Jul 10, 2008 09:42 AM
RE: LED ACCENTS
ok so therefor when the power for the amp is on the leds are on also. and what i understand, you them to be independent from that?
if so, splice a wire off your hotwire and run it to a switch and then run the leds to the switch you should be alright.
hope this helps, i always get confused on the grounds though, but i think this is right.
[IMG]local://upfiles/16233/4AF9E3EC8A0840F1AA8C835817853826.gif[/IMG]
Scubba.steve Jul 10, 2008 02:21 PM
RE: LED ACCENTS
http://i20.photobucket.com/albums/b2...345/Wiring.jpg
PoolhallJunkie777 Jul 11, 2008 12:05 AM
RE: LED ACCENTS
yes i believe it would. you are cutting the power off at the source. i havent spliced a wire since i had my lumina. but i rigged up a bunch of leds in that car to a switch and the hot wire was a splice of another. give me a few days or a week...ill test it out. i am short of time as of right now, also ill post some pics of what i did.
just dont do anything harsh yet. just give me some time and ill produce a solution.
