Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Stock audio no volume
Old Jun 27, 2006 | 01:38 AM
Nubiebubie_GSX's Avatar
Default Stock audio no volume
Well after amp replace with known working one, fuse check, and wires check i still dont know why i have no volume or maybe power to the speakers. It is a stock setup. When i got the car it required an audio code to unlock and i unlocked it. The headunit power on and load cd and scan radio, but no sound. Anybody have this sort of problem or know what is causing it.
Old Apr 5, 2007 | 07:44 PM
Sidmo's Avatar
Default RE: Stock audio no volume
I am having the exact same problem....any help would be appreciated!
Old Apr 6, 2007 | 10:19 AM
NubianSithLord's Avatar
what kind of car do you have? I had the same problem in my 03 Eclipse. even the steeringwheel buttons were working just no sound. It probably is the factory amp. the problem is Mitsubishi uses infinty sound systems. Which are very tempmental when it comes to altering them. I took my car to best Buy and Curcit city they both told me that I would have to change H/U and speakers... Not true the cheapest way to fix is get a aftermarget H/U and have someone bypass the amp and rewire the existing speakers. make sure u don't have the speakers with fuses for each one the dude at Best buy said that could be a problem to. What sucks is that after you do this your speakers may be crap but, you can always change at your lesiure. Good luck and God Speed I know it sucks to roll with no tunes. I have a issue with my sub and amp right now so I am nack to factory speakers myself hope to get new amp this weekend.
Old Apr 7, 2007 | 05:37 PM
WPSpyderGT01's Avatar
car year and model would be helpful sidmo =D
Old Apr 9, 2007 | 05:17 AM
50ul }{4ck3r's Avatar
do you need wiring schematics for the radio
seetherage
Mar 17, 2008 07:01 PM
dodo2
Feb 16, 2008 07:33 AM
hex
May 31, 2007 05:20 PM
agallardo
Aug 29, 2006 09:34 AM
agallardo
Apr 30, 2006 11:21 PM
