Chop Shop Show off your designs here. Or post to have your fellow members do some photo shop work to your ride.
Didn't finish car yet so I used the computer to
Old Dec 6, 2007 | 06:07 PM
Default RE: Didn't finish car yet so I used the computer to
Bigger rims dont make the overall diameter wider. All it does is remove some of the sidewall to acomodate the larger rim.
Anyone that has a ****ing clue about cars knows that less sidewall = crappier handling.
Old Dec 6, 2007 | 06:20 PM
5star's Avatar
ORIGINAL: Sebba
How so? Less side wall = less tire flex in the turns = better turning. Only thing I notaced is I feel the bumps more since theirs almost no side wall.
Old Dec 6, 2007 | 06:42 PM
ORIGINAL: 5star
ORIGINAL: Sebba
Hmmm guess that is why Evos get only 17 inch rims and all of the people who road race and autox use 16 or 17 inch rims so they can fit a bigger tire. tires being able to shape the road are a good thing. hard tires that will touch less surface and not grip as well. the bigger the rim the smaller the sidewall the worse the handling and the harder you hit bumps.
No offence but your reasoning behind alot of things you say is the exact opposite from being true. You are prolly one who believes convertables are lighter than coupse because they have no roof??
Old Dec 6, 2007 | 06:45 PM
If you are goingto argue you might as well KNOW what your talking about.
Old Dec 6, 2007 | 06:59 PM
5star's Avatar
ORIGINAL: Sebba
I was talking about the car is more stable in the turns with less side wall but its not to likely that any one is going to turn fast enough to go up on 2 wheels. And I knowthat for a fact from racin quad. And big tires and small rim and high horse power the tire can get fatter as you accolorate giving more traction from a wider foot print.
Old Dec 6, 2007 | 07:06 PM
Moron, the 'footprint' doesnt change. That is the surface area to the ground. It has jack **** to do with going up on 2 wheels. You still cant see the point, you are a moron.
Old Dec 6, 2007 | 07:21 PM
5star's Avatar
ORIGINAL: Sebba
What you talking about. You trying to tell me that the more side wall the more stable?
Old Dec 6, 2007 | 07:31 PM
Pretty much. You do realize that a car with 16's and a car with 19's actually have the same diameter tire right?
Lets just clarify, it means better grip.
Old Dec 6, 2007 | 07:36 PM
5star's Avatar
ORIGINAL: Sebba
Ya.
But im 100% sure that the less side wall the more stable/less tippy a car is. 100% postaive
Old Dec 6, 2007 | 07:39 PM
You are a ****ing moron....truely
