Eclipse Frequently Asked Question Section This section is only for FAQs, not Q&A. If you have an FAQ reply to submit, contact a moderator or admin.
95 ECLIPSE RS help plez
Old Nov 23, 2013 | 11:25 PM
crowles595's Avatar
Default 95 ECLIPSE RS help plez
Got 95 eclipse rs on day i was at stop sign and went to take off i hear a noise like i was dragging something and seen smoke poor out of tail pipe but stops when i hit 10 mph well the check engine light came on one day stopped at autozone to get it tested they said it was the iac valve so i bought new one took it home unhooked negitive battery terminal put the new iac valve in let it reset for 1 day and idel for 1hr turned it off and drove the next day for first time drove for an 1hr no ping or smoke then check engine light came back on but felt slight lose of power every now aNd then while driving got to autozonetested agian this time spark plugs not firing so bought newww while i was there and put them in then, (but i just changed 2mo ago) b4 this time, but spark plugs 234 was bad so changed all four, light went off, got gas another 20 min away so im an 1hr 20 min away from home but anyways got gas and drove home 3 miles away goin up hills i was losing power check engine agian get 3 blocks away and dies, try to start nothin let set 5min tried agian started but died like i was out of gas, is wat it sounded and acted like but tried agian stayed on put in drive died so let sit for 20min strarted and put in drive drove 2 blocks died at friends drive way so i let it sit 2 days went back started it had low and rough idel so i bought book for car well said something about egr valve, so i went from there looked at parts that relates to my car problems and related to the egr, soi bought a map sensor, iat sensor knock sensor,tp sensor, cmp sensor, egr valve and electric egr transducer solenoid, but not for sure if thats wat i need to fix problem ppl say and read things with same problem but i need mitsubishi ppl help lol some tp sensor some cmp sensor or even the blk fuse under hood and even someone told me timing belt can someone help asap tryin to get fixed or idea b4 wife goes in labor but the car sounds like it is flooded or had bad gas but its not bad gas done filled it up using gas jugs to dilute and idel 1hr
Old Nov 24, 2013 | 12:45 AM
Akzle's Avatar
well, i can't help you with whatever your problem is. mainly because i cant be bothered reading that ****,
so i'll help you with something else, it is spelled p-l-e-a-s-e,
and there's this button toward the right of your keyboard with "ENTER" on it, with which you can make sentences and paragraphs
and visually pause for effect.
neat huh?
also, try something at or above high-school english. seriously. can't be bothered.
Old Dec 8, 2013 | 04:18 AM
Biskitking's Avatar
Any luck with your problem?
Old Dec 8, 2013 | 08:42 AM
Akzle's Avatar
compression. Btw.
Black widow
Apr 29, 2014 10:30 AM
Robseclipse
Dec 18, 2008 11:57 AM
thomas4g63
Nov 28, 2008 12:52 PM
pablo1318
Jul 10, 2008 06:16 AM
enzo_hashmat2006
Jul 9, 2005 05:02 PM
