***Help??***compression problem?
Old Jul 12, 2013 | 12:42 AM
Christian Jensen IV's Avatar
Default ***Help??***compression problem?
Hey, hopefully someone here can help!! I have replaced the heads on my 2001 Montero Limited. Problem is...when I set the timing I get no compression on the passenger side head? All the timing marks are lined up and I have solid compression on all three cylinders on the drivers side. I'm totally stumped! Please help
Old Jul 12, 2013 | 12:45 AM
Pull the head off and check for bent valves. Sounds like there's an obvious problem.
Alternatively, do a leak down test with each cylinder on the drivers side at TDC, and see where those combustion gasses are escaping.
Old Jul 13, 2013 | 03:13 AM
Akzle's Avatar
do you mean to say you have compression before you do the timing?
because that would be odd.
head torqued down properly?
you'd have to have bent a valve(s) on every cylinder for it to show no comp on all 3.
Atlballazz06
Jul 29, 2010 01:52 AM
bossgrabber
Mar 4, 2009 06:21 AM
methanol_manic
1st Generation
Aug 30, 2008 04:32 PM
wega
Sep 30, 2007 11:48 PM
vertstanggt
Jan 9, 2005 12:13 AM
