01 Eclipse - Spark Plug broke - fell in motor
Hi there,
Hoping you can help with this problem on my Eclipse! I was driving at highway speeds when I felt my car shudder and the "Service Engine" light lit up. The car continued to shake, becoming worse while stopped at stoplights. I had it towed to the mechanic, where they determined that the ground electrode (L-shaped bracket) at the bottom of a spark plug had corroded/fallen off, and also the round tip had fallen in the engine. A compression test expelled nothing, so they had to open up the engine and find the broken-off parts. This was an expensive repair, and I would like to know who to blame (if anyone) Two notes: 1. I had taken the car in about a month ago to have the timing belt replaced at 76,000 miles. Could a this have contributed to the problem? (i.e. overheating/bad timing because of a poor installation) 2. My last tune-up (replaced plugs) was in Sept 2003 at 45,000 miles. No problems until this. Thanks! |
RE: 01 Eclipse - Spark Plug broke - fell in motor
Plugs can last 100Kmi.
They don't "corrode" (like rust) or fall apart. Timing would have to be off enough to cause excessive pinging to destroy a plug. Do you hear pinging ? Your plug is burning up . Too hot a spark ? Too much boost over a long period of time ? Try pulling the plug out after 10Kmi. and look at it. Is it degrading ? Did the mechanic inspect the condition of your rings ? A good vaccuum hose should suck metal pieces out of a cylinder. Just some thoughts. DT |
