01 Eclipse - Spark Plug broke - fell in motor
Old Jul 28, 2005 | 04:14 PM
trowa's Avatar
Default 01 Eclipse - Spark Plug broke - fell in motor
Hi there,
Hoping you can help with this problem on my Eclipse!
I was driving at highway speeds when I felt my car shudder and the "Service Engine" light lit up. The car continued to shake, becoming worse while stopped at stoplights.
I had it towed to the mechanic, where they determined that the ground electrode (L-shaped bracket) at the bottom of a spark plug had corroded/fallen off, and also the round tip had fallen in the engine. A compression test expelled nothing, so they had to open up the engine and find the broken-off parts.
This was an expensive repair, and I would like to know who to blame (if anyone)
Two notes:
1. I had taken the car in about a month ago to have the timing belt replaced at 76,000 miles. Could a this have contributed to the problem? (i.e. overheating/bad timing because of a poor installation)
2. My last tune-up (replaced plugs) was in Sept 2003 at 45,000 miles. No problems until this.
Thanks!
Old Jul 28, 2005 | 05:48 PM
Dans Talon's Avatar
Default RE: 01 Eclipse - Spark Plug broke - fell in motor
Plugs can last 100Kmi.
They don't "corrode" (like rust) or fall apart.
Timing would have to be off enough to cause excessive pinging to destroy a plug.
Do you hear pinging ?
Your plug is burning up .
Too hot a spark ?
Too much boost over a long period of time ?
Try pulling the plug out after 10Kmi. and look at it. Is it degrading ?
Did the mechanic inspect the condition of your rings ?
A good vaccuum hose should suck metal pieces out of a cylinder.
Just some thoughts.
DT
spyder4g63t
Oct 30, 2006 09:07 PM
TheAntiCivic
Jun 22, 2005 09:57 PM
Cat77
May 28, 2005 09:52 AM
97EclipseGS
Mar 21, 2005 08:30 PM
99eclipseguy
Dec 23, 2004 01:30 AM
