01 montero
Old Oct 22, 2013 | 10:52 AM
LUBO21's Avatar
Default 01 montero
cant keep my 2001 montero sport running once it gets warmed up. by suggestions i have already changed the fuel pump, fuel filter, and the fuel relay under the hood. anyone got any ideas??????
Old Oct 23, 2013 | 07:12 AM
mxmikie's Avatar
tps or iac
Old Oct 23, 2013 | 03:26 PM
LUBO21's Avatar
thanks i will look into that but wouldn't those give a fault code for the obd. i have not pulled any codes off the car as of yet.
Old Oct 28, 2013 | 02:56 AM
Jeff Collision's Avatar
Might be you have a bad mass air flow sensor or the snorkel from the mass air flow sensor to the throttle body could be ripped, it can cause your vehicle to loose power along with many other drive ability issues. If you need more help on how to repair your mass air flow sensor, I would suggest checking out this site How To section Repair mass Air Flow Sensor
lemmontero
Apr 28, 2010 11:33 AM
redturboeclipse
Dec 14, 2009 11:10 AM
autoseattle
May 10, 2007 06:17 PM
DarkManC
Apr 15, 2006 01:33 AM
fwank01
Mar 9, 2006 11:12 PM
