02 eclipse 2.4l 4cyl. P0340 and P0335
Old Mar 19, 2019 | 01:15 AM
Julio Juarez's Avatar
Default 02 eclipse 2.4l 4cyl. P0340 and P0335
Hey guys new on the forum and new to Mitsubishi, I recently bought an eclipse rs, had a leaking counter balance shaft seal so I replaced that and no oil leak but now car idles weird and when I’m trying to get going In first it dies on me and when I finally get going it just seems like it isn’t going anywhere can’t get past 30mph even if I shift up to 3rd gear. I had both of those codes pop up p0340 and p0335. Tested the circuit and sensors both seem fine. Would a timing slip cause these symptoms? I also did a spark and oil change on it since it sat around for a year (or so the guy said)
Old Apr 19, 2019 | 12:08 PM
Widgmaster's Avatar
Hello Julio ...
You are correct in assuming that a slipped timing belt would created the problem you are having. The two codes you give
p0335= Crankcase Position Sensor "A" - circuit malfunction
p0340= Camshaft Position Sensor "A" circuit malfunction (bank1 )
A slipped belt would obviously throw these two sensors out of line.
Some times we have to bite the bullet and have a professional check out these problems.... Best of luck Julio
jcdc
May 15, 2018 12:11 AM
kieferg933
Aug 9, 2017 12:49 AM
slavao
Feb 2, 2012 06:55 PM
Shepard69
May 20, 2011 08:50 PM
Rob
Jan 8, 2008 05:58 PM
