03 Galant Issues - Dire need of help!
Old Jul 10, 2005 | 04:48 PM
Joeyp2100's Avatar
Default 03 Galant Issues - Dire need of help!
I have an 03 Galant ES 2.4 w/ 14k miles. Recently - Within the last 2-3 months my car will die when I come to a stop. Let me explain a little more:
I will be driving down the road (35-50mph) w/ the A/C on and stereo on. Everything will run fine for a couple of miles. However, after those couple of miles and I need to come to a stop at a red light or what not, the RPMS will drop to around 100-200 and bounce in that area. This will cause the car to die and I now have to put the car in Park and Start it back up. It will start back up w/ no problems and go for another mile or so before it does it again. It wont do this at every light or every stop but in a 5-10 mile drive w/ 4-5 stop It will die 2-3 times. Ive come to find out that if I can see a stop coming up and I put the car in Neutral it reduces the chance of dieing but wont always work. In that same 5-10 mile drive It will die 1-2 times. I can keep it from dieing at all if I put it in N and give it a little bit of gas. All of my fuses are good, Fluids are good etc.... Any Ideas - I cant have this happen to many more times before something Bad happens!
Also, About 6 months ago I had my OEM deck stolen out of the car, However instead of unplugging it from the back of the deck, they cut it. So I went out and bought a new deck and had a friend wire it. Well After many failed attempts he got the unit to work, However every since then my Speed-O and Odometer wont work. Any ideas as to what I can do as far as possibly getting an OEM harness and plugging it back in to a Aftermarket and into the deck? or possibly a Wire Diagram for those wires that I can possibly get the gauges and deck to work? Thanks.
Thanks in advance for anyhelp and/or Ideas.
spench317
Mar 13, 2015 09:04 AM
quantumrift11
Jan 24, 2013 07:00 PM
Dietkrispy
Jun 19, 2011 09:38 AM
b_bruton77
Jun 23, 2004 10:04 AM
DarkrealmX
Feb 15, 2004 07:47 AM
