1990 eclipse turbo
Old Mar 30, 2006 | 08:46 PM
EXSUBE's Avatar
Default 1990 eclipse turbo
does any one out there know why the cam belts seem not to be connected to the crankshaft my manual shows a key and keyway. is this a common problem,whats the likelyhood of the nose of the crank being broken? any idea's thanks EXSUBE
Old Mar 30, 2006 | 09:17 PM
Default RE: 1990 eclipse turbo
If the crank was broke the car wont run. The crank is down the cams ar up and there are pulleys in between. it has to be connected other wise if you try to turn over you might have a valve problem after from vavles hitting the pistons
l-e-o-n-a-r-d
1st Generation
Jul 2, 2009 06:04 PM
Steve in VA
Aug 30, 2008 08:52 PM
fbmange1ofdeath
Dec 4, 2006 05:51 PM
fbmange1ofdeath
Nov 28, 2006 08:56 PM
towertag
Sep 17, 2005 11:48 AM
