1996 Mitsubishi GS makes a rattling noise after changing belts??
Old Sep 1, 2007 | 06:50 PM
hoss's Avatar
Default 1996 Mitsubishi GS makes a rattling noise after changing belts??
Hi everyone. I have a 96 mitsubishi eclipse GS 2.4 non turbo. I was changing two belts this afternoon, my power steering/ac belt and my alternator/water pump(?) belt. This is the second time i've replaced them, but this time, after everything was said and done, i tightened everything back up, checked all the bolts and fired the vehicle up and the belts do not squeel, but it is making a rattling noise, which kind of sounds like someone is tapping a wooden dowel back and forth between two blocks of wood. After listening and some visual inspection, nothing seems out of the ordinary, but it sounds like it is coming from the water pump pulley. Does this make sense? Anyone else dealt with this or know what it could be?
Thanks!
Old Sep 2, 2007 | 11:30 AM
hoss's Avatar
Default RE: 1996 Mitsubishi GS makes a rattling noise after changing belts??
Nevermind, started the car up this morning and found the problem. Smelled burning rubber and looked under the hood again. The belt in the back (i think its the one that drives the AC compressor) had come right off the track. The noise i heard was a wobbling pulley. It just happened to be the one belt i did not touch. It was not the pulley that i originally thought it was. The idler pulley was the culprit. The bearing is hitching and needs to be replaced. What caused it, i dont know, but glad that it happened now instead of later. Hope this helps others later on!
pd154
May 22, 2012 01:44 AM
phils06gt
Apr 18, 2012 12:10 PM
weldtech22
Dec 28, 2011 07:56 PM
masterxox
11
Mar 25, 2008 09:34 PM
A1CChubs
Apr 1, 2007 01:57 AM
