2.0 non-turbo engine shaking
Old Oct 17, 2005 | 02:22 AM
tjbiker031's Avatar
Default 2.0 non-turbo engine shaking
hey i got a '97 eclipse with a 2.0L non turbo, it runs great but when im stoped at a light it feels like the engine is shaking a lil too much and shakes the whole car and it idles at around 800 rpms.....i cleaned out the throttle body a lil with some carb cleaner and changed one of the O2 sensors before the cat and that seemed to help some but it still does it...am i mis-fireing on a cylinder or need a sensor somewhere? im changing the spark plugs and wires tomarrow maybe that will help Can anybody help?
Old Oct 17, 2005 | 03:48 PM
DSMTalonAWD51's Avatar
Default RE: 2.0 non-turbo engine shaking
most likely a cylinder isnt firing. just chance the plugs and check back
Old Oct 17, 2005 | 04:58 PM
Patrick's Avatar
Administrator
hmm..a 97..do you have a check engine light on? are you on stock mounts?
Old Oct 17, 2005 | 06:06 PM
RSEclipse's Avatar
i know may be a noobie car question..but since my car is lowered is it normal for the check engine light to come on?
Old Oct 18, 2005 | 01:29 AM
Joel_CA's Avatar
The 2.0L non turbo engine is well noted to leak oil down the spark plug tubes through the valve cover tube seals. This can cause a very erratic idle and and misfire under load/no load conditions. Since you're changing your plugs and wires- take a good look down the spark plug tube to see if there is oil down there. I've seen them filled to the top with oil! If this is the case, you'll need to replace your valve cover gasket including the tube seals. Good Luck!
Joel, CA
Old Oct 18, 2005 | 05:32 PM
autodoktor's Avatar
ORIGINAL: Joel_CA
Joel, CA
And as candle wires
Old Oct 18, 2005 | 11:34 PM
tjbiker031's Avatar
well i changed out the spark plugs and wires....no luck....but ill try the valve cover gasket and the tube seals. Thank for the help guys!!
Old Oct 18, 2005 | 11:41 PM
tjbiker031's Avatar
if i would buy a valve cover gasket... it would have the tube seals too right?
Old Oct 19, 2005 | 12:23 AM
Joel_CA's Avatar
They don't come together as a kit if that's what you're asking. If you DON"T have any oil leaking into the spark plug tubes- then you don't need to replace them.
Joel, CA
Old Oct 19, 2005 | 11:59 AM
slow420a's Avatar
ORIGINAL: RSEclipse
no it should not be on.
For the shaking is it auto? it may be a bad torque converter. My dads car has only 80k on it and its doing the same thing. If a cyl was misfiring you would know. The car would bearly run and the check engine light would flash. It could also be the motor mounts like pat said. Those tend to go bad b/c their made from a really crappy rubber.
