2.4 oil change
Old Oct 4, 2020 | 10:00 AM
Homer1959's Avatar
Default 2.4 oil change
I just bought a new to me Outlander 2019 ES with the 2.4. Before climbing under I wonder If I will need nothing for the drain plug, or a new rubber seal or a copper crush washer.
Thanks guys
hummmm ....should I be worry about the CVT on a 2019 ?
Old Oct 4, 2020 | 03:19 PM
DibbyDibbyDJ's Avatar
You will need a sump plug washer.
CVT oil due at 90000kms or 45000 severe use. oil should be clean blue/green colour.
Old Oct 4, 2020 | 08:25 PM
Homer1959's Avatar
Dibby thanks, however I didnt express myself properly, I need to know what kind of engine oil drain plug do I have and what I need to get before draining the oil, is it a plug with a rubber gasket the one you can re-use again and again, or is it a one time metal crush washer , Ill keep the info for the tranny for sure :-)
Old Oct 5, 2020 | 12:54 AM
You will need a sump washer. it is a crush type, Available from Mitsubishi. It is a unique type.
17mm spanner to undo.
39 Nm torque to tighten
4.3 litres of oil to refill including filter
Old Oct 5, 2020 | 07:13 AM
Homer1959's Avatar
ok I got it thanks a lot for your patience :-)
First time that I see the name sump washer , I guess that even after 40 years as a mech. in the railroad that I will have always something new to learn lol lol
thanks Dibby
krieg
Apr 5, 2022 06:00 PM
XeoNoX
Mar 4, 2020 11:53 AM
mrdawgza
Dec 6, 2016 11:33 AM
Vadimus
Nov 26, 2010 12:13 PM
jgmacdaddy
Jan 9, 2005 12:49 AM
