2007 2.5 did L200 mil flashing.
Old Aug 19, 2021 | 05:23 PM
Looneyfitter's Avatar
Default 2007 2.5 did L200 mil flashing.
Hope everyone is well. Womdering if anyone could help? Ive changed a faulty injector on my l200. I have coded the ecu with the new injector. It wont start and the mil is flashing. Any ideas? Im told this engine doesnt need pilot learn?
Cheers Gareth
Old Aug 20, 2021 | 02:49 AM
DibbyDibbyDJ's Avatar
You havent given an engine code so i am assuming it is a 4d56?
When a new injector is fitted the MIL wont go out until the car has done a small quantity relearn. When the engine is up to temp it will happen on its own, or if you have access to a scantool, you can force it to relearn, but the engine and gearbox and fuel must be within a certain parameter range.
But yours doesnt start, so you arnt quite there yet. Was it starting ok before you replaced the injector?
wm10001
Sep 14, 2015 05:34 AM
jamesg1979
Oct 29, 2011 03:06 PM
jetskilee
Aug 17, 2011 12:10 PM
kruc
Jan 26, 2010 01:49 AM
gowie77
Other Mitsubishi Models
Dec 11, 2007 08:43 PM
