3000GT died!
Hello all- I have a 1995 3000GT. The other day my starter went out. Bought a new one and put it in. Next day alternator went out. Installed it along with a new battery. Car started right up and ran for about 30 mins. When I was heading down the road- it died! No warning, no check engine light. Pushed the car home, and tried to start it- no go. It sounds like it is going to start, but it does not. I hooked it up to my truck to try and jump it, but nothing! I checked fuel- good there. Checked spark- good there! The car is right there, ready to go, but I can not figure it out. Any help or ideas would really help!!! Could a bad starter or bad alternator cause it to die like that? THANKS!!!
RE: 3000GT died!
So, your getting fuel and spart... just not igniting? It could be a vacume line or something... it could be your ECU. I find it really odd that all this stuff keeps going out... are you sure you dont just have an electrical fault?
RE: 3000GT died!
I also think it is weird that everything went south at the same time. However, the starter had been going bad for some time. SO if there is a hole in the vaccum line- could that cause the car to die like it did? Also, if the ECU went out- would I still get a spark? Thank you very much for your input!
RE: 3000GT died!
I think you would still get spark. It would all depend on the extent of it. There are so many things that could be wrong its really hard to say. I would look at the timing too. Maybe your T-Belt sliped a few teeth.
If you are getting spark and fuel and its still not ignitin that leads me to believe that there is not enough air getting to the system. |
RE: 3000GT died!
Im going on the ECU idea. It cant be the t belt because the car would still start it would just run really bad.
