4g63 swap
Old Mar 24, 2008 | 03:31 PM
mmp803's Avatar
Default 4g63 swap
i have the 4g63 motor for my oz rally lancer but i cant find the motor mounts for the swap. if anyone knows whee i can find the mounts let me know. thanks allan.
Old Mar 24, 2008 | 04:28 PM
darknigh7th's Avatar
Default RE: 4g63 swap
can you swap a 4g into a regular lancer? I'm not sure.
Old Mar 24, 2008 | 07:40 PM
silvercoupe97's Avatar
Worse case scenerio...make 'em.
Wait, are you talking about recent version of the 4g63 from the Evo 4-9 or are you talking about the Evo 1-3/Eclipse/Galant 4g63?
I'm going to assume you mean the motor from an Evo 8-9. Are the engine bays the same between Lancer and Evo? I'm going to assume, yes, since they are the same car. If so, I'm going to suggest taking the mounts off the original Evo and welding them into your Lancer...yes, you'll have to cut them out of the Evo and cut an opening, using the Evo as reference, in your Lancer to weld them into and, yes, you'll have to measure. If that doesn't work for you, measure, measure, measure, and measure some more and have the mounts fabricated.
Old Mar 25, 2008 | 12:56 PM
but the lancer and the evo are the same in body only i believe, i'm pretty sure even the frame is different.
Jdg784
May 1, 2006 09:41 PM
mrfc3s
Sep 13, 2005 05:57 AM
T88Spyder
May 29, 2005 01:42 AM
betterdayz19
Oct 24, 2004 11:59 PM
betterdayz19
