94 eclipse Alternator trouble ! !
We have a 94 Eclipse 1.8
the car will not start. We Checked the starter "tested fine" , then bought a new battery. Still no start. The next morning the battery was dead. So we pulled the alternator and got it checked. It was fine but . . . we noticed there was a wire "possible ground?" not connected to anything at all. We cant find where it goes. What is this wire for and what does it connect to? Would it stop the car from starting? Could it be the reason the bat is drained overnight? below is the wire . . . http://img151.imageshack.us/img151/8701/img00219i.jpg The wire comes straight off the cluster of connectors that attach to the back of the alternator. srry camera phone pics best i could do right now. http://img156.imageshack.us/img156/7836/img00220e.jpg What is this wire ? where does it belong conected to? We need to get this car running asap. any help would be amazing! |
Thats for the the p/s pressure switch.
go to autozone they can help u out
Originally Posted by eclipselaxr18
(Post 248869)
Can some one confirm the P/S reply? There is allot of bad information on forums and i want to get this problem sorted out asap. Anything else i could try? I have confirmed the starter , alternator , and battery are good. Fuses look good to. |
I know 100% it goes on the p/s pump. I can get you a pic if need be.
the alternator must be stoned. LOL
that's a funny profile pic. he must be holding a roach. |
Did you have anything constructive to add BEAT?
Originally Posted by dsm1990gsx
(Post 248894)
Well then that would not stop the car from starting. We still have the main problem car will not start ,and battery is drained by morning if its left hooked up. ???wtf? I have verified that the battery , starter , and alternator are good. Fuses i am pretty sure i checked and are fine as well. Whats next? What could i check? The dizzy? hmm maybe thats it i will check it out. Any other suggestions? |
It has nothing to do w/ it not starting.
Does it crank? |
Well we push started it a couple times. so yes it will start. But the last time we made it to the bottom of the hill it didn't start. You gotta know that that sucked as.
So it dosen't crank? If the starter tested good do you have power at the starter?
