95 Diamante stalling
Old Feb 23, 2008 | 06:22 PM
smccant1's Avatar
Default 95 Diamante stalling
I havea 95 Mits Diamante LS DOC that won't stay running in idle and cuts off at stops. What can be the problem?
Old Mar 4, 2008 | 10:37 PM
jgbrules's Avatar
Default RE: 95 Diamante stalling
hello! i would first adjust the idle properly, then if you still have an issue, replace the idle speed control motor. that is a common problem. good luck!! greg...
Old Mar 5, 2008 | 02:10 PM
dsm1990gsx's Avatar
Sounds like a bad isc motor. Try hitting it w/ a small hammer and see if it holds an idle.In the winter a lot of fords wont idle b/c the isc motors stick and if you hit them and they start to idle you know that is your problem.
elmiserable
Jan 20, 2009 08:18 PM
elmiserable
Jan 20, 2009 08:13 PM
autorok
Jul 1, 2005 02:33 PM
get435
May 22, 2005 03:12 PM
1998blackgst 240
May 9, 2005 07:50 PM
