95 FTO GR
Old Sep 7, 2008 | 05:14 PM
FTO_Steve's Avatar
Default 95 FTO GR
When i first start the car in the mornings or after being left for a long period of time the car keeps on stalling until it has warmed up for a few minutes, anyone got any ideas as to what is causing it to stall? any help would be much apreciated
Old Sep 7, 2008 | 08:45 PM
Default RE: 95 FTO GR
New plugs and spark plug wires.
Don't buy that performance ****, just get good ole NGK Classics and Mitsubishi spark plug wires... IF you can.
Old Sep 8, 2008 | 03:50 PM
dsm1990gsx's Avatar
Do u have a check engine light? Could be a vacuum leak at the intake manifold, it'll leak when its cold (vacuum leak=stall) then when it warms up it seals (no vacuum leak=no stall).
Old Sep 8, 2008 | 08:23 PM
Even if he did, there wouldn't be a place in the UK where you can walk in an use the OBD II scanner.
Old Sep 9, 2008 | 11:58 AM
dsm1990gsx's Avatar
ORIGINAL: Sebba
Ok...well idk I never lived there lol.
Old Sep 14, 2008 | 01:47 PM
HandyPal's Avatar
Hey Steve,
In addition to what has been said above I would like to mention coolant/air tempertature circuits. Check the sensors that run to ECU. Any fault in this area greatly affects cold starts.
To get a better idea about what is going on I would recommend monitoring voltage on O2 sensor to see if the engine is running lean or rich. It should be slightly above 1V (depending on type of sensor, check with some tech info for your car) and almost constant at cold and fluctuating below 1V at warmed up condition.
Good luck and funtroubleshooting.
JAP80X
Jun 5, 2005 09:35 AM
poolsharkjunki
Mar 2, 2005 08:54 PM
BIG SID
Oct 22, 2004 01:53 PM
RamaTu3927
Feb 24, 2004 02:40 PM
silvia240cnvrsn
Dec 22, 2003 02:16 PM
