96 Montero P1400 help!
Old Sep 19, 2011 | 11:07 AM
jmslmartinez's Avatar
Default 96 Montero P1400 help!
Got a code P1400 (Manifold Differential Pressure Sensor circuit) changed the MAP sensor and air filter, and reset the check engine light. about a week later it came back with the same code. I dont see any loose hoses/connectors, and it seems to be running pretty well, it just drives me crazy seeing it there! What would you guys try next? Thanks in advance!
Old Sep 30, 2011 | 10:05 PM
mxmikie's Avatar
how did you reset the cel ????
Old Oct 1, 2011 | 08:13 AM
I reset it with the same scanner I used to download it.
Old Feb 10, 2013 | 11:58 AM
Nasser's Avatar
I have a Diamante 2001 that had a P1400 check engine code. I replaced the manifold differential pressior sensor or mdp sensor part # MD305600 and that took care of the problem. Advance Auto wanted $167 for it I got it from LKQ for $5. Pull-a-part may have some cars that may have it also because this part is used in many Mitsubishi modules.
Eclipsor
Jan 25, 2022 03:08 PM
le0128
Feb 10, 2013 11:59 AM
gringo7161
Dec 1, 2011 07:59 PM
jmslmartinez
Sep 19, 2011 11:29 AM
nhlfreak1
Apr 18, 2007 11:03 AM
