99 Galant engine/transmission swap
RE: 99 Galant engine/transmission swap
negative. tranny swaps can be done. They are done all the time. You just need a tranny out of a v6 00-05 eclipse.
I have seen this done plenty of times. My friend has personally been a part of 2 v6 galant tranny swaps and 3 I4 galant tranny swaps.
check out this post
and as far as cost it varies with how much you get the used tranny for, and if you are going to keep it stuck or upgrades...
after reading your post again. if you have the I4 2.4 and you want to make it a v6 5speed, I don't believe that is doable.
But you can make your I4 5speed. And you can even swap an evo motor into your car as well.
check out this post
BigSteve0034
05-20-2005 03:42 PM
2000, 2001, 5sp, 5spd, 99, diamante, eclipse, galant, interchange, mitsubishi, swap, tranny, trans, transmission, v6
