apexi install on 99 mirage was 1.5 now its 1.8
RE: apexi install on 99 mirage was 1.5 now its 1.8
You either have a mas or a maf... all efi cars do, so yes you can but you need to "make it work"... same thing with the 420a, their are no directions by apexi for the install but it can be made to work.
Why are you installing it though, if you dont have cams or a turbo setup(which require bigger injectors) you will destroy your motor. The safc is ment to lean out and control injectors that are larger than the stockers. On a stock fuel system it wont give you any hp.
anko_kun
08-11-2006 04:45 PM
