Automatic Gear shift stuck
Old Jul 15, 2007 | 05:58 PM
adro1982's Avatar
Default Automatic Gear shift stuck
Recently had 2002 Diamante heater core repair- had to take dash out and steering column- now gear shifter is stuck - will only go into neutral and drive- key will not come out of igntion. Any ideas?
Old Jul 15, 2007 | 08:29 PM
silvercoupe97's Avatar
Default RE: Automatic Gear shift stuck
Open the center console again. I'm willing to be that the moving parts were put back correctly (alignment). Just follow the shifter lines.
I've had this issue with my old auto too and all it was, was the shifter's lock (moved by the button on the shifter handle) was getting stuck on the steps...you'll see what I'm talking about.
Just take the center console out and move the shifter around (try to anyway) and try to find the obstruction. You'll have to do this with the key in but motor does not have to be on.
Ms.Fixit
Sep 23, 2010 10:55 AM
Ms.Fixit
Sep 12, 2010 01:43 PM
adro1982
Jul 15, 2007 12:26 PM
Doober247
Apr 3, 2006 08:10 PM
Jdg784
Jan 22, 2006 05:01 PM
