BADGES
Old Apr 18, 2007 | 06:02 PM
steelcurtain043's Avatar
Default BADGES
jus tryna figure out how to take off my eclipse, rs, and mitsubishi badges (stickers). i was told fishing wire. any suggestions.
Old Apr 18, 2007 | 06:04 PM
Dusty Eclipse's Avatar
Default RE: BADGES
Huh? fishing wire? Dunno how that would work... but i know a way... But first, tell me that you ARENT going to put a new sticker there that says GST/GSX.
Old Apr 18, 2007 | 06:07 PM
Default RE: BADGES
NO WAY..JUS LEAVIN IT BARE. NO STICKERS...TO TELL U THE TRUTH I DIDNT EVEN NO PEOPLE DO THAT.LOL
Old Apr 18, 2007 | 06:09 PM
Default RE: BADGES
Yes. They do it all the time. Or at least they did on DPA. Use a heat gun and/or a simple plastic disc.
Old Apr 18, 2007 | 06:12 PM
Default RE: BADGES
YOU REALLY HAVE HELPED ME OUT. BUT MAYBE IMA LITTLE SLOW BUT IM NOT UNDERSTANDING THE WHOLE PLASTIC DISC THING. ILL PROBABLY BE BETTER OFF USING THE HEATING GUN.
Old Apr 18, 2007 | 06:15 PM
Default RE: BADGES
Yea, heat guns what I used on my old GSX... Was quick and easy.
Old Apr 18, 2007 | 06:19 PM
Default RE: BADGES
I KNOW THIS ISNT THE RIGHT FORUM PAGE BUT IF U CAN GIVE ME ADVICE ON MY NEXT PROBLEM. WENI HAVE PRESS ON THE ACCELERATOR I CAN HEAR LIKE WATER MOVIN I DONT HAVE WATER IN MY ENGINE BUT I DUNNO WHAT THIS IS, BUT I THINK IM ALSO LEAKING OIL FROM MY HEADER. SHOULD I JUS FIX IT OR CAN I DO AN ENGINE SWAP.
Old Apr 18, 2007 | 06:27 PM
Default RE: BADGES
When you say an engine swap, I assume you would mean to another 420a? You couldnt have water in your engine, at all, as if you did it would be hydrolocked (water doesnt compress) that could be a myriad of things... where are you leaking oil from?
Old Apr 18, 2007 | 06:30 PM
Default RE: BADGES
WEN I POP MY HOOD I SEE A BUNCH OF OIL RIGHT AROUND THE TOP OF MY ENGINE (LIKE ITS LEAKING FROM MY HEADERS...I THINK). I JUS GOTTA OIL CHANGE LIKE LAST MONTH AND MY OIL LIGHT IS ON. I HAVE 2 PUT MORE OIL IN LIKE EVERY 3 WEEKS.
Old Apr 18, 2007 | 06:31 PM
VR4GARY's Avatar
Default RE: BADGES
Do not use a heat gun! It can damage the paint. Use a blow drier instead. You don't have to heat it up very much and they peel right off.
