a board oil-indicator - HELP !!!
Old Jun 8, 2005 | 06:42 PM
alex5073's Avatar
Default a board oil-indicator - HELP !!!
Hi everybody!
I drive Pajero '86 TDI and I have a problem with the indicator showing the oil compression.
The scale is from 0 to 8 and since couple of days the needle point at 0 and very rarely rises to the highest level and again to zero. The oil quantity in the motor is enough.
When it worked properly with engine starting the needle goes up to 6 then down to 2 and stays there till the engine is on.
What is the problem?
Is it only fauty indicator or something serious?
Thanks in advance!
Alex
Old Jun 8, 2005 | 10:24 PM
99clipsgst's Avatar
Default RE: a board oil-indicator - HELP !!!
It sounds like you have very low oil pressure and I would have a mechanice run some test on it. when you have low oil pressure then you engine parts arnt getting enough oil to safely coat your vital engine parts. So it would be in your best intrest to get it down to the shop asap
Old Jun 9, 2005 | 08:08 PM
alex5073's Avatar
The indicator was disconected.
I fixed it and nou is OK
10cs
user 27474884
33
Jul 30, 2024 07:53 AM
GPSeek
Oct 24, 2023 08:18 PM
yura
Aug 20, 2005 11:00 PM
Knaackers
Jun 14, 2004 06:32 PM
Guyver007
Sep 22, 2003 04:30 AM
